fastEddie wrote: http://www.maxmotors.com/snipers-for-vipers/4846/ Surprisingly not based out of Texas.
Yes, and YES
There is one good -- if nerdy -- reason to not hotlink pics. The domain lookups and server calls absolutely crush page load times, which in turn makes google unhappy and penalize a site.
That said,
eastpark wrote: 2012 Boss Mustang:
Someone please explain that weird exhaust crossover. Does this thing have dual tail pipes and dual side pipes?!
nderwater wrote:eastpark wrote: 2012 Boss Mustang:Someone please explain that weird exhaust crossover. Does this thing have dual tail pipes and dual side pipes?!
Electronic Cut-outs for the track? That is the only thing I can think of.
Edit* web site only lists it as a Quad exhaust...
carguy123 wrote: It's big! It's heavy! It's got a solid rear axle! But I can't help myself, I want one! It's got just the right stuff for meeastpark wrote: 2012 Boss Mustang:
Let's see. Solid rear axle, check. 440 hp - no, I'm betting it's between 350 and 400. But it only weighs 2400 lbs and is smaller than a Miata
By the way, the Boss does indeed have factory exhaust cutouts. Not electric, I think you have to remove a plate.
Keith wrote:carguy123 wrote: It's big! It's heavy! It's got a solid rear axle! But I can't help myself, I want one! It's got just the right stuff for meLet's see. Solid rear axle, check. 440 hp - no, I'm betting it's between 350 and 400. But it only weighs 2400 lbs and is smaller than a Miata By the way, the Boss does indeed have factory exhaust cutouts. Not electric, I think you have to remove a plate.eastpark wrote: 2012 Boss Mustang:
440hp IS the stated HP but it's definitely NOT smaller than a Miata, although it feels like it from the inside. It's on a full size car chassis not a smaller pony car chassis and it's no where near 2400 lbs. 3200-3400 I'd believe.
carguy123 wrote:Keith wrote:440hp IS the stated HP but it's definitely NOT smaller than a Miata, although it feels like it from the inside. It's on a full size car chassis not a smaller pony car chassis and it's no where near 2400 lbs. 3200-3400 I'd believe.carguy123 wrote: It's big! It's heavy! It's got a solid rear axle! But I can't help myself, I want one! It's got just the right stuff for meLet's see. Solid rear axle, check. 440 hp - no, I'm betting it's between 350 and 400. But it only weighs 2400 lbs and is smaller than a Miata By the way, the Boss does indeed have factory exhaust cutouts. Not electric, I think you have to remove a plate.eastpark wrote: 2012 Boss Mustang:
I believe Keith was Juxtaposing the Boss Laguna against his MGBGT LS1 car... As shown on a lift in his last picture. His MG has a solid rear axle, a 350ish horsepower engine, and a smaller than miata body.
carguy123 wrote:
If you sum these forces the car eventually doesn't stay on the ground. It does this.
The perfect back flip with 1/2 twist. Didn't stick the landing though...
FlightService wrote:carguy123 wrote:If you sum these forces the car eventually doesn't stay on the ground. It does this. The perfect back flip with 1/2 twist. Didn't stick the landing though...
Hey, now!
Peter Dumbreck managed to stick a four-point landing, albeit a bit off track:
And survived essentially unscathed; he's still racing in the FIA GT1 World Championship.
Maroon92 wrote:carguy123 wrote:I believe Keith was Juxtaposing the Boss Laguna against his MGBGT LS1 car... As shown on a lift in his last picture. His MG has a solid rear axle, a 350ish horsepower engine, and a smaller than miata body.Keith wrote:440hp IS the stated HP but it's definitely NOT smaller than a Miata, although it feels like it from the inside. It's on a full size car chassis not a smaller pony car chassis and it's no where near 2400 lbs. 3200-3400 I'd believe.carguy123 wrote: It's big! It's heavy! It's got a solid rear axle! But I can't help myself, I want one! It's got just the right stuff for meLet's see. Solid rear axle, check. 440 hp - no, I'm betting it's between 350 and 400. But it only weighs 2400 lbs and is smaller than a Miata By the way, the Boss does indeed have factory exhaust cutouts. Not electric, I think you have to remove a plate.eastpark wrote: 2012 Boss Mustang:
Exactly. I thought it was funny that I had the same picture of my own car.
I never noticed the 2nd car wasn't the Boss.
In reply to carguy123:
Yeah, it was that great big red MG badge on the front that gave it away for me. And the smaller Corvette badge on the grille that gives a bit of preface to the engine noise.
I still want to stuff one of these in a notchback mustang and go run in the "all-motor" 4 cylinder class.
