tuna55
tuna55 MegaDork
10/14/16 8:46 a.m.
SVreX wrote: In reply to tuna55: The exception to my explanation is if the source begins at a switch instead of the fixture. THEN it is possible to read 120V at a switch. I am assuming your diagram showing the source at the fixture is correct. The other time 120V could be at a switch is if it is used as a junction.
The switch appears to be the first stop for the wiring from the crawlspace, and was indeed used as a junction.
SVreX
SVreX MegaDork
10/14/16 10:09 a.m.
In reply to tuna55:
Ok, then the neutral must pass through that box and get directly to the fixture. It DOES NOT connect to the switch.
Everything else about my previous instructions is the same.
tuna55
tuna55 MegaDork
10/14/16 10:28 a.m.
SVreX wrote: In reply to tuna55: Ok, then the neutral must pass through that box and get directly to the fixture. It DOES NOT connect to the switch. Everything else about my previous instructions is the same.
Wait, what?
How does the switch switch if power doesn't go through it?
RossD
RossD UltimaDork
10/14/16 10:41 a.m.
Just the neutral passes through without connection to the switch.
Refresher: http://www.askmediy.com/how-to-wire-a-3-way-switch-with-video/
I think I look at this every time I try to do some home wiring, lol.
SVreX
SVreX MegaDork
10/14/16 10:56 a.m.
Wait, what? How does the switch switch if power doesn't go through it?
Switches NEVER have power (meaning, they never have both the hot and neutral). They only BREAK the circuit of the hot.
Hot goes through the switch. Neutral does not.
If you put hot on one terminal and neutral on the other, you would dead short it the minute you turned it on.
tuna55
tuna55 MegaDork
10/14/16 8:53 p.m.
So like this?
Hal
Hal UltraDork
10/14/16 9:28 p.m.
tuna55 wrote: So like this?
Exactly. The actual feed wire may come into the box for the fixture first in some cases, but you still feed it down to the switches and then back to the actual fixture.
spitfirebill
spitfirebill UltimaDork
10/16/16 9:42 a.m.
Whenever I get old enough to take free classes at a tech school, I am going to take an electrical class. And an AC class.
tuna55
tuna55 MegaDork
10/17/16 7:01 a.m.
Got that figured out. Bad wiring and a bad switch.
Now there is a sweet hole cut in the wall, and then we're on to the stairway and the wiring in the kitchen.
Thanks guys!
tuna55
tuna55 MegaDork
10/18/16 6:53 a.m.
Kitchen happy also now.
Now to trim the hole and the aforementioned stairway
ys1LnUvd1DPWjH4Aucgq9GRy5LSBOt8uUrpn9OWvzeIciGix876dEzOCJVSQGhW4
