After a little over two years and countless theories and experiments, I've finally determined where my water pressure spikes come from.
Hot water and thermal expansion.
We have a "closed" system here at the house, with a backflow preventer on the main. This gives expanding water nowhere to go, except the overflow on the hot water tank or any faucets.
Well the overflow on the tank is brand new as of when we moved in, as is the house pressure regulator/back flow preventer, and the meter itself.
The water pressure spikes throughout the house after using a bunch of hot water, like a shower or the dishwasher.
I've been trying to size tanks but the calculators I've used ask for measurements I don't know how to make, and the tanks I've seen for sale cap at 155psi. This is a problem because my pressure peaks at 175psi.
Our nominal pressure is set at 70psi. We have a 40 gallon hot water tank.
I'm sick of blowing seals in my bidet, toilets that sound like bombs going off, dripping shower heads and puddles on the floor by the water tank.
So let me recap in a list real quick.
40 gallon tank
70 psi nominally
Surges to 175 after hot water usage.
Main line is 3/4", drops to 1/2" before the hot water tank and splitting to cold for the rest of the house.
Almost all tanks I've seen are rated for a max of 150psi.
How big of a tank do I need and where should I put it with regards to the plumbing around the HWT?
