93EXCivic
93EXCivic MegaDork
10/24/22 7:11 a.m.
Since GRM knows everything, is there a device out there that could measure distance to 50ish feet pretty accurately without putting a visible laser on the thing you are measuring? I know some phones have LIDAR but mine doesn't and golf/hunting rangefinders don't have the level of accuracy that I want. I know I can buy a LIDAR sensor but I don't really want to build something if I don't have to.
dean1484
10/24/22 7:23 a.m.
I think there may be military  stuff that uses lasers that are not in the visable spectrum for that. Not sure it is available to the public.
10/24/22 8:08 a.m.
A typical laser measure won't have a visible dot outdoors during the daytime at that distance. The nicer ones have a small video screen with crosshairs so you can see you where you're aiming.  They'll be good to about 1/16" at that distance, if you have a good target.
You might see a tiny red dot if you are the actual target, but it will be pretty washed out.  Most people won't notice  anything at all.
Toyman!
10/24/22 8:32 a.m.
IIRC, my Bosch measurer doesn't fire a visible laser.
Edit to say, it's a pretty old one. It looks like most of the new ones do have a visible laser.
jharry3
jharry3 GRM+ Memberand Dork
10/24/22 8:52 a.m.
Land surveying theodolites have had laser distance finders for years;  at least since the 80's when I last did land surveying.
The laser was not visible on the one we used.   I don't think a visible laser is required anyway, I think its just there for aesthetics.
93EXCivic
93EXCivic MegaDork
10/24/22 9:01 a.m.
In reply to Duke :
I am mostly going to be using it for lower light tbh. I have some scale focus cameras and when using the lens wide open it can be difficult to nail focus.
1SlowVW
1SlowVW Dork
10/24/22 9:19 a.m.
How exact do you need to be? Golfers have different range finders that some use, may be worth looking into.
93EXCivic
93EXCivic MegaDork
10/24/22 9:27 a.m.
In reply to 1SlowVW :
Preferably within a few inches at 5-10 ft. The problem I saw with the golf rangefinders is they are made for much longer distances and the accuracy was a few feet.
Puddy46
Puddy46 New Reader
10/24/22 9:33 a.m.
Dumb question, but is there a reason you can't just use a tape measure?
93EXCivic
93EXCivic MegaDork
10/24/22 9:37 a.m.
I am wanting to use it to measure distance if shooting wide open with an old scale focus film camera. I want something a bit faster and more subtle then pulling out a tape measure.
Puddy46
Puddy46 New Reader
10/24/22 9:40 a.m.
In reply to 93EXCivic :
Ahh, gotcha.  Yeah, a tape measure definitely isn't your weapon of choice then.
WonkoTheSane
WonkoTheSane GRM+ Memberand UltraDork
10/24/22 10:05 a.m.
I have a little bosch laser "Tape measure" with a visible light (red) laser.  I just checked, and it will not work without that laser being visible.  I tried covering it up, and the device stops working.
Honsch
Honsch Reader
10/24/22 1:53 p.m.
The laser is the measuring device, so you can't cover it up, it's also a handy way to tell where you're measuring to.
Why is the laser dot a problem?  It's only there while you're measuring.
You might be able to find an ultrasonic distance measuring device, but you won't be able to pick a target like you can with the laser.
EDIT:
Go on amazon and search for "ultrasonic tape measure"
gSnqNqZoHfPKRYwKFFeq1VvyM81gihjWYraG72mC9asrtjsZRZTLBPJ38OH8eoJe
