1 ... 1540 1541 1542 1543 1544 ... 1808
David Elfering
David Elfering GRM+ Memberand Reader
3/10/24 11:46 a.m.
3/10/24 1:43 p.m.
3/10/24 1:44 p.m.
ShawnG
ShawnG MegaDork
3/10/24 1:55 p.m.
In reply to 914Driver :
There's also a small room just behind main entrances. Usually with a rather unfriendly person waiting to give you a good bashing when you stepped through.
3/10/24 3:55 p.m.
In reply to ShawnG :
And the ceiling of this room usually contained murder holes, for murdering you through.
3/10/24 4:58 p.m.
Steve_Jones said:
I love that this image is from a late 70s Mazda rotary.
That's two sets of points and two vacuum advance mechanisms.  You rotate the whole distributor to set leading, then slide the trailing vacuum advance can in and out (two screws) to adjust trailing.
NickD MegaDork
3/10/24 5:33 p.m.
1988RedT2
1988RedT2 MegaDork
3/10/24 5:48 p.m.
In reply to Pete. (l33t FS) :
That sounds confusing.  My '73 RX-2 had two distributors.
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fi.imgflip.com%2Fqiev6.jpg&f=1&nofb=1&ipt=1319efc1a21d86eced7820d48e68edb8c667ead69db61b266fef5919a0f723f9&ipo=images
NickD MegaDork
3/10/24 5:49 p.m.
3/10/24 6:01 p.m.
3/10/24 6:08 p.m.
3/10/24 6:14 p.m.
ShawnG
ShawnG MegaDork
3/10/24 6:34 p.m.
In reply to 1988RedT2 :
Packard v12, 2 6 cylinder distributors in one.
Set base timing on the first bank of cylinders with a light bulb on the points.
Rotate engine to the next timing mark and move the second, adjustable set of points to bring the second bank into phase with the first.
Verify both with a timing light while running.
It's confusing when you read the process in a manual but easy once you've done it on the car
Later Lincoln V12s have to be set up off the car.
67LS1
67LS1 Reader
3/10/24 8:13 p.m.
tomtomgt356 (Tommy)
tomtomgt356 (Tommy) GRM+ Memberand Reader
3/10/24 9:42 p.m.
tomtomgt356 (Tommy)
3/10/24 9:44 p.m.
tomtomgt356 (Tommy)
3/10/24 9:45 p.m.
tomtomgt356 (Tommy)
3/10/24 9:45 p.m.
tomtomgt356 (Tommy)
3/10/24 9:46 p.m.
tomtomgt356 (Tommy)
3/10/24 9:47 p.m.
travellering
travellering Dork
3/10/24 10:17 p.m.
tomtomgt356 (Tommy) said:
It's got a cold electron intake kit, sport tuned center console screen with over 11000 nits, and for a little boost at the track, my buddy hooked me up with a couple half-farad caps from the car audio guy at the flea market..
RealMiniNoMore (Forum Supporter)
RealMiniNoMore (Forum Supporter) PowerDork
3/10/24 10:57 p.m.
3/10/24 11:01 p.m.
Steve_Jones
Steve_Jones UltraDork
3/11/24 12:12 a.m.
Floating Doc (Forum Supporter) GRM+ Memberand UltimaDork
3/11/24 12:26 a.m.
QtrSwHkaW8ipPZ9zNW3nFQCot9Z6Pedsq6sVChOVsX7BV8nWf0cVzrXjWMyGdpwt
