Bspec V 2.0:
RACE RULES:
Full Simulation Crash Damage and Tire Wear will be on. There is no specific trans. You can run Auto, Manual or Manual w/clutch. Manual w/clutch is recommended for quicker lap times. Please respect your fellow driver. If you question a move, like dive bombing someone going into 10A at Road Atlanta, potentially ruining both your and your opponent's race, don't do it. Don't cut track. We all blow a turn and push off, or brake/turn in early and hop a berm now and then, but if you can't cut a clean lap outside of qualifying, please don't bother running with our group. Proclaiming "On your inside" is no excuse for divebombing. Please don't cry when you get pinched. To put it simply: DON'T DRIVE LIKE AN A$$HOLE. All cars must display numbers corresponding to GRM Username and xbox live gamertag. Numbers are required on both sides of the car and roof or hood.
PRACTICE/QUALIFYING:
An "Official practice" will be held at (Time tbd) followed by a ten minute break, followed by qualifying.
For Qualifying, we will be using the "Time Trials" approach, where our times will not be affected by the draft and other cars in the way as they are invisible. It will be a 10 minute session. PAY ATTENTION TO WHERE YOU FINISH. Take note of who should be in front of/next to you on the start. There will be another 10 minute break between Qualifying and the feature race.
FEATURE RACE:
We will take the standing start lap as our "warm up" lap to warm tires and get gridded up in our qualifying positions. At the end of the standing start lap, the race will begin via a 2x2 rolling start. Odd numbers (position, not car number) will be on the OUTSIDE of the turn 1. Even numbers on the inside. He who has the pole will call "GREEN."
SCHEDULE:
Saturday 9/22: Indy Gran Prix Circuit: 25 laps. Pit 10 - 20.
Saturday 9/29: Motegi Full: 20 laps. No pit.
Saturday 10/6: Nurburgring GP Short: 25 laps. Pit 10 - 20.
Saturday 10/13: Mugello Club: 30 laps. Pit 10 - 25
Saturday 10/20: Road America, f*ck yeah: 15 laps. Pit 5 -10
Saturday 10/27: Road ATL full: 25 laps. Pit 10 - 20
Saturday 11/03: Top Gear Outer Loop: 30 laps. No pit.
Saturday 11/10: Sunset full: 25 laps. Pit 10 - 20.
Saturday 11/17: Suzuka Full: 15 laps. Pit 5 - 10.
Saturday 11/24: Hockenheim National: 25 laps. Pit 10 - 20.
POINTS
1st - 25
2nd - 18
3rd - 15
4th - 12
5th - 10
6th - 8
7th - 6
8th - 5
9th - 4
10th - 3
11th - 2
12th - 1
(Up for discussion:) "Drops;" Each competitor will drop his/her worst event. This event will not count toward points total.
CARS AND SPECIFIC ACCEPTABLE/REQUIRED MODIFICATIONS
Mazda 2 (C355)
112hp, 1864lbs. Sport Brakes, Sport Suspension, Race Sway Bars, Full Cage, Full Weight Reduction, Street Clutch, Street Axles, Race Diff, Race Compound Tires in 205/50s, Spec Enkei RPF1's in stock size, Sport Exhaust, Race Flywheel (updated 6.4.12)
Nissan Versa (C361)
122hp, 2,348lbs. Sport Brakes, Sport Suspension, Race Sways, Race Cage, Full Weight Reduction, Race Diff, Street Clutch, Street Transmission, Race Axles, Race Compound Tires in 195/60 15s front and rear, Spec Enkei RPF1's, Race Flywheel (updated 6.6.12)
Toyota Yaris S (C360)
106hp, 2,053lbs Sport Brakes, Sport Suspension, Race Sways, Race Cage, Full Weight Reduction, Race Diff, Race Compound Tires, Spec Enkei RPF1's in stock size, no motor mods. (updated 6.4.12)
Ford Fiesta (D347)
118hp, 2,009lbs. Sport Brakes, Sport Suspension, Race Sway Bars, Full Cage, Sport Weight Reduction, Race Diff, Race Tires, Spec Enkei RPF1s in stock size, no motor mods. (updated 6.4.12)
Honda Fit (C362)
128hp, 2,174lbs. Sport Brakes, Sport Suspension, Race Sways, Race Cage, Full Weight Reduction, Race Clutch, Street Transmission, Race Axles, Race Diff, Race Compound Tires, Spec Enkei RPF1's in stock size, Sport Exhaust (updated 6.4.2012)
Kia Cee'D (Rio)(C356)
150hp, 2,378lbs. Sport Brakes, Sport Suspension, Race Sways, Full Cage, Full Weight Reduction, Race Diff, Race Compound Tires, Spec Enkei RPF1's in stock size, Race Exhaust, Race Oil and Cooling, Race Flywheel, Street Air Filter (updated 6.4.12)
