Taiden
Taiden Reader
11/1/10 10:23 p.m.
Hey all,
I'm looking for some creative ideas.
I am renting a house right now, and the garage is large and drafty. I make a good amount of money working in the garage, and I need to come up with a plan to insulate and heat it on a shoestring.
This would be a lot easier if I owned the house. I cannot make permanent changes to the garage. I only use one bay so I had a thought to build a simple 'box' around the bay I plan to use.
Any suggestions would be helpful
I'm not the type to go to home depot and buy everything new, there are are few building supply recyclers around here, and I might find something there.
Thanks all
RoosterSauce
RoosterSauce New Reader
11/1/10 10:48 p.m.
Tear the foam out of old car seats and stuff it into the cracks around door jambs and windows. If it's just an open ceiling, put something up there to keep the heat in like a bunch of cardboard taped together. Stretch some old chicken wire fencing across the garage and paper mache it to split your garage in half. Grab some old bricks or cinder blocks and build a fireplace. You'll need a hood and chimney to catch the smoke and channel outside. You can make this out of sheet metal scraps. Make sure you have the number to the fire department.
turbojunker
turbojunker HalfDork
11/1/10 10:52 p.m.
sheet plastic
RoosterSauce
11/1/10 11:00 p.m.
turbojunker wrote: sheet plastic
That's not creative; that actually makes sense.
jrw1621
jrw1621 SuperDork
11/1/10 11:02 p.m.
Staple up large sheets of cardboard as insulation. Laying cardboard on the floor can also provide some protection from cold cement. Keep flames and sparks to a minimum.
turbojunker
11/1/10 11:02 p.m.
I'm lazy.
Knurled
Knurled GRM+ Memberand HalfDork
11/1/10 11:20 p.m.
Duct-taping cracks and seams is huge. Anything you can do to prevent drafts will make an enormous difference.
Depending on the work you do, you could throw down some cheap carpeting. Now's a good time to find used carpeting on trash day, as people get new carpeting installed in time for the holidays.
Taiden
Taiden Reader
11/2/10 8:35 a.m.
Thanks for the ideas. Sheet plastic to section off the bay, and ducttape to seal up the drafty cracks I think will make a huge difference.
And RoosterSauce: All I gotta say is LOL!
Zomby woof
Zomby woof Dork
11/2/10 8:39 a.m.
Find the guy in your town that recycles the old water heaters for the local utility, and hit him up for some used insulation.
The sheet plastic, and cardboard are both great ideas.
DoctorBlade
DoctorBlade Reader
11/2/10 9:05 a.m.
Sheet plastic does come in some very thick sizes. I saw one guy on the web who built himself a homemade spraybooth with 2x4's and some thick sheet plastic.
curtis73
curtis73 GRM+ Memberand HalfDork
11/2/10 9:22 a.m.
I knew a guy who scrounged around CL for free magazines and newspapers (and other paper products). He put it in a big 55 gallon barrel with some water and made paper slurry. Then he dumped in a gallon of glue and slung it on the walls with a shovel. Worked OK and he had to go through a few types of glue to find one that worked well.
Best part was that he used an old air-cooled outboard 3 hp motor in the barrel to chew up the paper.
... then shortly after that someone posted 6 bales of fiberglass batting for free on CL
Karl La Follette
Karl La Follette HalfDork
11/2/10 9:25 a.m.
refridgerator boxes ,paint white for more light inside garage
stuart in mn
stuart in mn SuperDork
11/2/10 10:37 a.m.
Are the walls bare studs, or have they been covered with sheetrock or some other finish surface? Also, where do you live? Insulation requirements vary from Minnesota to Florida.
In general, seal up the cracks and remember that heat rises - you lose more heat out of the roof than the walls.
internetautomart
internetautomart SuperDork
11/2/10 10:40 a.m.
if you aren't doing anything with flames, then use old blankets nailed up.
81gtv6
81gtv6 GRM+ Memberand Dork
11/2/10 11:02 a.m.
Check to see if you have a Habitat Restore near by. If so you should be able to get isulation very cheap.
Also check any construction sites near you. Show up and talk to the forman, tell him what you want to do and chances are he will give you the OK to pick through the dumpsters. I was able to insulate my garage door and finish the outside walls in my garadge with cast offs from job sites, just be sure to ask first.
triumph5
triumph5 HalfDork
11/2/10 11:15 a.m.
Related to the plastic, cheap, large tarps tied/stapled in place. Duct tape the seams, and weather stripping on the doors/windows. Harbor Freight has "ceramic" heaters on sale; they put out a fair amount of heat for their small size and power consumption. Plus they're portable, put it anywhere.
sachilles
sachilles HalfDork
11/2/10 2:20 p.m.
I believe he is from Portland ME. So think damn cold, and breezy.
Make sure you cover the windows with plastic to reduce the draft. Report back as to what the inside of the structure is like, is there any insulation or what?
Taiden
Taiden Reader
11/2/10 2:27 p.m.
It's pretty much an old barn-type structure. Drafty, and I am about 400 feet from the ocean. The cape (as the name suggests) sticks out into the ocean, which means less snow, but more wind.
Duct taping seams will be CRUCIAL I'm sure. The windows are also quite drafty.
There is no insulation at present. The garage doors are new, but not insulated.
It has a very high ceiling (~20 feet at the peak), so boxing that in will also be crucial.
I'm also trying to decide on a method for heating that is also budget oriented. I'm pretty paranoid about fumes, but if it's safe, it's safe.
Also, there is a local Habitat Restore, I will visit them before I buy any materials. :)
sachilles
sachilles HalfDork
11/2/10 2:47 p.m.
If this is a temporary gig. Plastic over the windows and either plastic or paper stapled over the exposed wood work. Makes it easy to remove. Plastic above you is critical. Put plywood or cardboard on the few feet near the floor over the plastic, to prevent it from an accidental tear. Get a direct vent heater(check on codes before install, some need to be higher off the ground. This alone will make a HUGE difference. Maybe a pair of electric socks would be a good gift to suggest to a loved one for the upcoming holidays.
Xceler8x
Xceler8x GRM+ Memberand SuperDork
11/2/10 2:49 p.m.
Think you could cut a deal with the landlord on rent by insulating his garage? Something like "Hey, I'll insulate the garage for materials cost if you'll cut the materials cost from my rent? What do you think?"
He might go for it...
akamcfly
akamcfly Reader
11/2/10 7:05 p.m.
I was surprised at how inexpensive fiberglass bat insulation was when I priced it.
internetautomart
11/2/10 7:54 p.m.
Xceler8x wrote: Think you could cut a deal with the landlord on rent by insulating his garage? Something like "Hey, I'll insulate the garage for materials cost if you'll cut the materials cost from my rent? What do you think?" He might go for it...
that is basically how I got the HVAC setup in my office.
foxtrapper
foxtrapper SuperDork
11/3/10 7:24 a.m.
Lowes and Home Depot sell 20'x100' rolls of 6 mil plastic sheeting for about $40 a roll. You can quite well seal off your bay with that.
For heat, one of those propane tank mounted infra red heaters do a dandy job. True, propane is not cheap, but if you're not trying to heat the bay constantly, it's pretty cost effective.
triumph5
triumph5 HalfDork
11/3/10 7:53 a.m.
Not to be a downer, but a good idea would be to have a fire extinguisher (Fire Ice is amazing) and a monoxide detector--odorless, colorless-- in the booth.
Gasoline, heat, evenings, close quaters, etc...and that's in the summer, outside! And your landlord will appreciate seeing those items in the garage now, before you start the project. Made points with a landlord pointing out my extinguisher in my kitchen.
Taiden
Taiden Reader
11/3/10 8:53 a.m.
Extinguisher and monoxide detector are fantastic ideas (not a downer) and will be on my list of must-haves
E3OoGOO0WqqRyGpERBSY5264LHMPk8bpO8ZiixQewDDsjV0F5gQXJR2AupWJxnUO
