fiesta54
fiesta54 Reader
9/9/15 6:40 p.m.
Basically I need to be able to have a metal rod move up and down through the hull of a jon boat while obviously keeping water tight integrity. It doesn't need to pivot or anything crazy, just move up and down. What type of search terms can I use?
RX8driver
RX8driver New Reader
9/9/15 6:47 p.m.
Stuffing box and/or shaft seal should get you started.
fiesta54
fiesta54 Reader
9/9/15 7:12 p.m.
Thanks! those are some good starting points
9/9/15 7:58 p.m.
dare I ask what you are using it for?
In all honesty, a stuffing box and shaft seal are mostly made for things that rotate.. like the shaft that runs the prop. If all it is going to do is go up and down, you may be able to get away with a simple pipe that is sealed to the bottom of the boat and comes up above the waterline. The steering Shaft on my sailboat's Rudder is a simple piece of bronze bonded to the 'glass of the hull.
At most, you may need a small seal at the top to keep water from spraying out the top at speed
KyAllroad
KyAllroad SuperDork
9/9/15 9:31 p.m.
Stuffing box and shaft seal sound like euphamisms for something much less nautical.
NOHOME
NOHOME UberDork
9/9/15 10:20 p.m.
Mad-machine nailed it. All you need is a tube bonded to the bottom of the boat that is taller inside the boat than the waterline is outside the boat.
What are you doing? Is it just an anchor spud or something more novel?
fiesta54
fiesta54 Reader
9/10/15 9:12 a.m.
Wow, yea the tube is such an easy solution. I think I might be able to make something along those lines work. Great idea
fiesta54
fiesta54 Reader
9/10/15 9:12 a.m.
In reply to NOHOME:
Something a little bit more novel. I'm not quite in the reveal stages yet but hopefully soon
9/10/15 3:32 p.m.
I wait with baited (heh) breath
oR69OBDRZBlnyN2AQc93NrLFF9RIVyxwL4kjalsaEUqpny5ZvTJRSJMIlZsRl6vX
