MiniDave
MiniDave Reader
3/7/23 1:06 p.m.
Most of the tanks I've seen are designed to be low and flat, I need one that's more vertically oriented to fit in the space I have available, in the front of a Mini between the uprights and not too wide or deep (front to back). 10 gallons would do it, I could get by with 8.....
If I can't find a reasonably priced fuel cell or fuel tank that will fit the space I may have to weld up my own, but I'd sure prefer the easy button.
When I look at Summit Racing for example, while they offer what seems like thousands of fuel cells, after paging thru a few hundred they all seem to follow the same patterns, and their search function doesn't seem helpful. I understand why race oriented fuel cells would prefer to be low and flat, but there must be other cars that require a different shape to fit space available?
It doesn't have to be a fuel cell, just a properly shaped gas tank would work as it's not a track car....but I wouldn't mind the added safety of a fuel cell .
Dimensions that would work - 18-20" wide, same height and 8-10" deep, smaller than that would be even better, less deep is more helpful that shorter or narrower......I'm not good at math so I don't know how many gallons the smaller of those dimensions would provide so someone with more smarts wants to weigh in I'd appreciate it!
Slippery
Slippery GRM+ Memberand PowerDork
3/7/23 1:11 p.m.
18" x 18" x 8" = ~11 gallons.
How many gallons would be acceptable?
volvoclearinghouse
volvoclearinghouse UltimaDork
3/7/23 1:20 p.m.
Older pickup trucks had tall, skinny tanks that mounted behind the seat.  Maybe something like that?  or maybe a fuel cell designed for that application?
Here's one for Jeeps, 18 gallons, might be able to find somethign smaller:
https://www.amazon.com/JEEP-FUEL-TANK-BEHIND-ALUMINUM/dp/B07J2TKCWK
MiniDave
MiniDave Reader
3/7/23 2:20 p.m.
In reply to Slippery :
8-10 gallons is plenty, slightly shorter than 18" would work fine, the 8" wide is good....so maybe 18 wide, 16 tall and 8 deep are what I'm shooting for?
Slippery
3/7/23 3:20 p.m.
The math is like this:
18 in x 18 in x 8 in = 2592 in^3 / 231 = 11.2 gallons
18 x 16 x 8 = 2304 / 231 = 9.9 gal
volvoclearinghouse
3/7/23 3:24 p.m.
An option, easy but likely more expensive:
https://www.pyrotectstore.com/custom-fuel-cells/
A search for "custom fuel cells" pulls up a few other options
Out of stock, but an option:
https://www.wescoperformance.com/8gallonupright.html
MiniDave
MiniDave Reader
3/7/23 4:18 p.m.
Thanks, I guess the key thing I didn't know was how many cubic inches in a gallon
MiniDave
MiniDave Reader
3/7/23 4:20 p.m.
In reply to volvoclearinghouse :
I also found an outfit in Ca that says they make custom tanks so I sent them and the Pyrotect folks both a note asking for a quote. I have a feeling the Pyrotect folks will be way more money than I can spend for this but thanks for the links!
Slippery
3/7/23 4:29 p.m.
In reply to MiniDave :
If you dont mind, please share the price once you get a quote.
Indy - Guy
Indy - Guy UltimaDork
3/7/23 7:29 p.m.
Have you tried eBay?  Search for 8 & 10 gallon fuel cells, most list exterior dimensions.  A stock tank is going to be the cheapest option.
MiniDave
MiniDave Reader
3/7/23 7:44 p.m.
Will do....
MiniDave
MiniDave Reader
3/7/23 7:45 p.m.
Pyrotect called back and said anything they could do would be really expensive as a one off - I was pleased that they took the time to call.
MiniDave
MiniDave Reader
3/7/23 7:47 p.m.
In reply to Indy - Guy :
Yes actually, I spent quite a bit of time on there.....most everything on offer is designed to sit flat under a trunk or back seat, where I need it to stand up so to speak. All the ones that go behind the seat like in a 70's pick up truck are way too big.
volvoclearinghouse
3/8/23 9:44 a.m.
jimgood
jimgood Reader
3/8/23 10:02 a.m.
If you can't find exactly what you need, maybe start with something like this, cut it and weld it back together:
MiniDave
MiniDave Reader
3/8/23 1:49 p.m.
In reply to jimgood :
Now that's what I'm talking about....I can't weld aluminum but I know someone who can, we could slice a chunk out and weld it right back to make it short enough. Good find!
If I made it 20" long it would be right at 10 gallons - perfect.
Thanks for that link!
jimgood
jimgood Reader
3/9/23 7:45 a.m.
You're welcome. Glad to be of service. Hope it works out.
gVxhwVcf3uG52lCVqLN54dW7rKpww8LyUnjwyZq2ICuXzBWAVP9QreIiRmlwN8Kp
