snipes
snipes Reader
5/10/10 2:10 p.m.
I am making a cafe seat for the GS400 and I am looking for some DIY seat foam. I want it very firm and no more than 2" think. I was thinking about chopping up the lady's yoga mat, but chickened out.
Appleseed SuperDork
5/10/10 5:25 p.m.
Fabric shops have tons of foams. That'd be were I'd start.
93gsxturbo
93gsxturbo Reader
5/10/10 8:15 p.m.
For thick, cheap foam, buy a high density foam sleeping pad from Walmart, and rubber cement the layers together, then shape it how you want.
Josh
Josh Dork
5/10/10 9:23 p.m.
I did up my bike seat with pieces of a "bottom cut" of super high density memory foam from a place called Dynamic Systems. It's awesome. For about $30 shipped, I got enough foam to do at least a half dozen bike seats. I used the excess to make seat inserts for both of my race seats in the Miata, and I still had enough left over to use as a bedroll for trackside camping (works great, but isn't exactly packable).
http://grassrootsmotorsports.com/reader-rides/458/seat-redo/
http://www.sunmatecushions.com/sunmate_discounts.php
I got mine in "medium", and IMO it worked great for the seats. For someone a little lighter, or after a more plush seat, the softer ones might work better, but I think the medium would be perfect for you.
snipes
snipes Reader
5/11/10 11:50 a.m.
Nice. Did you build up the bottom cuts to make it thicker. What did you glue them with. Thank that looks perfect.
Josh
Josh Dork
5/11/10 12:01 p.m.
Yeah, I built up about 3 layers in the middle of the seat, and then contoured it with an electric turkey knife and a coarse body filler rasp. I used 3m Super77 to adhere the layers together. My seat is probably a lot thicker than you are looking for, though. I know the links says the sheet is .75" thick, but that's more like a minimum. It's not perfectly even as you can see in the pic, but the sheet I got probably averaged 1-1/8" or so. You can also easily fillet off that bubbly crusty layer if you have an electric knife, and that will leave you with around 3/4-1" of foam clean on both sides. If you are going to do this, get an electric turkey knife, totally worth the $15 or so (less if you hit a yardsale or something). You will hate yourself trying to cut this stuff with anything else.
44Dwarf
44Dwarf HalfDork
5/11/10 1:49 p.m.
HINT: Place foam in the freezer for an hour or so before shaping make it cut alot better! PS: don't let wife see you do it..
44
p2bcTnWx1wYSISB93qI0GDXrYx00B1NVBTjckJ8B8rN4TNfshC0OJevG2ZjtxoYC
