2002colossalfailure
2002colossalfailure New Reader
4/29/15 8:45 p.m.
I'm starting in a suspension rebuild (1998 neon) and learning as I go. There's a lot of rusty subassemblies, most probably not touched in over a decade. How do you take these apart so the bushing can be replaced? This side is OK, but the bushings on the other side (exhaust) are half gone.
Rad_Capz
Rad_Capz HalfDork
4/29/15 10:11 p.m.
Usually sway bar end link kits are cheap enough with all new hardware that you can just cut the old stuff if it's giving you a hassle.Check prices for yours.
Kenny_McCormic
Kenny_McCormic PowerDork
4/29/15 11:23 p.m.
You can probably grab a new pair for $20 and save a lot of hassle.
MCarp22
MCarp22 HalfDork
4/30/15 12:46 a.m.
Looks like you have a Suspension Techniques 21mm rear swaybar there:
http://www.stsuspensions.com/extras/docs/DGBT/51002%20(Dodge_94-98_Neon_Rear%20ASB).pdf
The factory stuff wouldn't be compatible with that. You could either contact ST and get replacement parts, or the bolts / rod ends are available from hardware suppliers like mcmaster carr.
Hope that helps.
2002colossalfailure
4/30/15 5:34 a.m.
The exploded view on page 4 is just what the doctor ordered. Thanks
gcAmcOHywiDTDLz7L81nBYr9hGkcfXYYpGYUoje5EMkjwAIkTMm6hNv7Aofc4s0u
