Karacticus
Karacticus GRM+ Memberand SuperDork
12/13/22 10:06 a.m.
I'm purchasing a drop deck trailer with aspirations of towing the Supra around to a lot more track events, though I expect it's also going to get a bit of use moving our garden and compact utility tractor around between the house and clinic.
The perimeter (well at least the front and sides) incorporates L (Logistics?) track along the entire edge.  However, the track is only drilled to allow for the insertion of studs towards the corners/ends of the trailer.   If I use wheel tie downs, I'll want double stud anchors pretty much at the wheels, and I assume I'll have to drill those locations-- you don't just want them free to float.
It's aluminum, so I assume it's quite straightforward to use an appropriately sized hole saw, perhaps clamping something in place to locate the pilot-- and maybe if I get smart I can use that to lay out the spacing for the double stud hardware?
aNfChrgUYB0cbJwSrPgdsFqWb1E793Xkue2I8Ja1j0FQATRakLUWAwNI0SgrHqMW
