Hello, all, I'm starting planning on my 202X challenge X1/9's roll bar.
To be as succinct as I can, here are some details as best I can project them.
Finished weight, below 2000 lbs.
Wheelbase:86.69" +/-
ET< 13.49
Convertible (no side windows)
Modified floor pan (I believe this is a big one) Modified chassis as well.
Engine swap PT Cruiser GT drivetrain
-What I'd like to do is a 6 point roll bar. Hoop, two diagonals going to rear shock towers, two side bars going forward to mid rocker.
Some more tubular bracing between the main hoop and rear shock towers would be really nice-can I do a partial tube frame trellis? The frame rails need pretty extensive mods for drivetrain fitment anyway.
-According to my research, I should use 1.75 OD .120 wall thickness tube (I'd like to stay with mild steel). Does the hive agree?
-Can I weld a firewall to the main hoop? Can I recess and weld it to my Targa bar? Does anything change if I weld a roof on?
I'll try to find it, but I believe Patrick found a database where you could find pre-bent main hoops and order them cheap. I tried Jegs, will hit Summitt next and post here for posterity if I have any luck.
Here's a picture of what I am looking for in a main hoop if anyone just happens to know of one fitting these dimensions.
It's true, I draw like old folks berk, but, there you go.
All responses appreciated.
Be well, everyone.
