ok, so recap of the first event. Saturday was 75 degrees and beautiful. When I left my house at 530am Sunday it was 60. At the mountain, the temps quickly went down and it was really windy, in the 40s all day but felt a lot colder (and so much blowing dust)
Anyhow, one of DC's largest events ever with almost 65 drivers registered. MR class as expected was big, with over 15 drivers registered. Making it even more intense, we had all the front-of-the pack regulars from last year - Nick D in the M3, Sennett in his M52 e30, Stephen and Chris in the 325i, Neil and Eric in the 325i, and others. So right there is about six guys who have won at least one event in the past year or so. To add to that, Jeff Geier, who was one of the faster guys two years ago, returned from his year-long adventure motorcycle trip around the continent and got right back into going fast in his co-driven 325. Aaaand, Jeremy Sitar, one of the fastest guys in Appalachian region 2 years ago, returned to rallycross in his e36 328i. To add to that, Dan Gugger left his M10 e30 at home and showed up with a Porsche 944 on fresh rally tires. Plus we had a couple Miatas and a couple BRZs, plus a few other newbies. So that's a lot of fast movers, any of whom can win on any given day.
Huge group....65 cars coming up the hill to grid
The MR crew
From the start, I knew it was going to be tough. With the M42 it was quick and balanced, and you coudl pretty much just put the pedal to the floor and go. On my first couple runs, I found out the hard way that the torquey M50 isn't going to have that, as I almost spun a couple times and killed a few cones in the process. My times weren't awful, but they weren't great either. I was running soft DMack gravels up front and hard DMack gravels on the rear, and keeping the tail under control was quite a bit of work, as the car would over-rotate in anything tight. This was exacerbated by only having replaced one trailing arm, while the other one was still 1/2" toe out, giving some tendency to snap oversteer under braking.
By lunch break my cones and some sloppy driving overall put me out of contention, something like 15 seconds behind the class leader, Nick. So, people ate lunch...
Meanwhile, I messed with the car. I switched on my Maxsports (much softer tread and sidewalls) to the rear in place of the hard gravels, and I strapped two spare wheels/tires into the trunk to get some weight in the back.
So up we went for afternoon runs. And whadya know....I worked on modulating the throttle more and "point-and-shoot" more coming out of turns with later throttle application, and on the 2nd run of the afternoon I had the fastest time in the class for that run. The rest of the afternoon runs I ran pretty consistently. A few people had faster runs and I did pick up another cone, but overall the car felt pretty good and I started to get the hang of what it wanted to do. Overall I think I picked up a couple seconds on Nick in the afternoon, and finished in 6th place. So, not terrible considering the lousy start and the huge amount of talented competition.
Nick won, beating Sitar by 2/10ths of a second and once again hitting no cones (neither of them did) - though Nick, remember, I know you hit one that didn't get counted, because you said you did ;) But, it only counts if someone calls it in!
So, this isn't autocross so what you did on one or some runs is irrelevant. However, for the sake of metrics I did a quick look at just the afternoon runs at the top of our class:
Nick: 334.3 seconds (no cones)
Jeremy: 331.6 seconds (no cones)
Chris H: 335.1 seconds (no cones)
Eric E: 336.9 seconds (+1 cone = 338.9)
Stephen: 335.8 seconds (+2 cones = 339.8)
Me: 333.8 seconds (+1 cone = 335.8)
Jeff G: 338.3 seconds (+4 cones = 346.3)
Neil : 339.6 second (+1 cone = 341.6)
Josh S: 341.1 seconds (+3 cones = 347.1)
Takeaway: If you are pretty quick and hit no cones, you will probably be on the podium
Sooo....on raw time alone I was faster in the afternoon than everybody except Jeremy, and he was absolutely flying. The one cone i did get was on my last run with Julian riding shotgun where we were kind of goofing around late in the course and I overshot the turnaround. So, afternoon *could* have been a bit faster, to boot. So, I feel pretty good about the afternoon driving - looking at the numbers I was a bit better than I thought I was. With some fine tuning hopefully I can get back into contention at the next event, just have to calm down on cones and be consistent.
So, some takeaways and notes:
I need the "rally weight" in the trunk with these M3 springs, just like I did with the M42. Two tires seems to be about right, with a mostly-full tank of fuel. Now I have enough power to not worry about weight.
Front springs felt GREAT. I went up 25lbs of rate, but they actually feel way better than they did before.
Refreshing my braking system paid dividends, as the brakes felt really good and were only tranction-limited in one or two spots.
The drivetrain feels VERY responsive in all ways. I will note that with sold motor and transmisison mounts, man, my tranmission has substantial increase in NVH. Even the brand-new throwout bearing I can hear easily with the clutch pressed, With the clutch out and in neutral, there is a high level of layshaft/input shaft bearing noise from the transmission. It was likely there before, but I had soft poly mounts on it before rather than UHMV through-bolt ones. Getrag transmissions from e30s are known to have noisy bearings at high miles and it isn't said to be a major issue, but boy it is very apparent now. Also an audible gear whine that I couldn't really hear before. Just to test whether it's just the extra NVH from the sold mounts vs. something actually wrong, I'll probably throw some stock mounts in this week and go drive around and see what it sounds/feels like.
Diff: The 4.10s are just too short. Luckily this course was more technical than the usual Panthera courses (the two big straight hills were too torn up and rutted to run), so I could do the whole course in 2nd, but on a "typical" course here I would have needed 3rd a few times, which I'd prefer not to do. So I will almost certianly put my 3.73 LSD diff back in the car. It was a bit too long for the M42 that liked to rev, but should be just about right with this engine.
I pulled that diff off the shelf and tested the breakaway torque on the LSD, and it was taking close to 60lb-ft to break away - so that says it's locking up right about where it should.
So, will get that diff and the other trailing arm in this week. My new skidplate should be in tomorrow as well so will get that fitted up this week.
random: This newcomer e30 was just an M20, but the previous owner had planned to put a Yamaha Taurus SHO engine in it with ITBs, so built this hood to fit it (and never fitted the engine).
