1 ... 12 13 14 15 16 ... 31
Gimp (Forum Supporter)
Gimp (Forum Supporter) GRM+ Memberand UltraDork
7/6/21 11:05 a.m.
asphalt_gundam said:
These plastic rolls work great for air dam material. Its what I used on mine.
Colored Plastic Rolls, 25 Ft. (speedwaymotors.com)
That's exactly what I used too.  It's now air dam, and some inner wheel wells to keep dirt out of fun places.
jh36
jh36 HalfDork
7/6/21 5:53 p.m.
In reply to Gimp (Forum Supporter) :
Ok, thanks to you both. I am putting in an order. And I also need a shift light and they have the one I want....so, win win.
jh36
jh36 HalfDork
7/7/21 7:29 p.m.
Looks like the shift light wiring will be simple, connecting to the tach lead in the pod. Tonight I switched out to my favorite safety harness (sabelt) and measured for decals for show. I will place the order tomorrow.
On the downside, Jegs sent me 1.5" bar clamps instead of the 1.75" I ordered...although the package says 1.75". Awesome customer service though...Mike from Jegs jumped right on it. I think we will be straight by the weekend.
jh36
jh36 HalfDork
7/9/21 8:43 p.m.
I just took some time and read through my thread, from the beginning. So much excellent advice and positive re-directing has happened since I started. I really appreciate all the ideas you guys have offered up through this project.
jh36
jh36 HalfDork
7/11/21 10:46 a.m.
A few things have come off the "to do" list before vir.
First of all, I put my Sabelts on the car and put on a new(er) seat cover.  It feels little more like home now.
jh36
jh36 HalfDork
7/11/21 10:47 a.m.
I decided to make a more robust batter hold down.
jh36
jh36 HalfDork
7/11/21 10:48 a.m.
I will trim the tops of the rods a bit and put on rubber caps...although it isn't as close to the wiring as it appears.
jh36
jh36 HalfDork
7/11/21 10:49 a.m.
I started decorating yesterday.
jh36
jh36 HalfDork
7/11/21 10:49 a.m.
Javelin (Forum Supporter)
Javelin (Forum Supporter) GRM+ Memberand MegaDork
7/11/21 12:28 p.m.
In reply to jh36 :
Spalted maple veneer on the dash is now a requirement...
jh36
jh36 HalfDork
7/11/21 12:31 p.m.
In reply to Javelin (Forum Supporter) :
Ha ha!  Maybe I can find a way to incorporate some of that idea!
7/11/21 1:25 p.m.
In reply to jh36 :
That decal is perfect! Have you considered adding smaller ones to each quarter panel?
jh36
jh36 HalfDork
7/11/21 2:07 p.m.
In reply to Pete Gossett (Forum Supporter) :
Yes!  I have two. I'm waiting for a couple of other decals to arrive so I can space them well.
jh36
jh36 HalfDork
7/11/21 8:23 p.m.
I started feeling out the cross brace to stop the dreaded hood deflection/throttle lock.
I started by attaching a couple of bar clamps 1/4-20 threaded rod going through 3:4" square stock.
jh36
jh36 HalfDork
7/11/21 8:25 p.m.
Since the hood is contoured, the center needs to be higher so I'm thinking I will weld a piece to the center after determining the proper height and profile. I will use this piece as a gauge by clamping it to the cross bar at various heights until I have the right fit and no hood deflection
jh36
jh36 HalfDork
7/11/21 8:42 p.m.
Once I have one brace sorted that I am happy with, I plan to make three. One on either side of the throttle and one toward the front edge of the hood.
NOT A TA
NOT A TA SuperDork
7/11/21 9:01 p.m.
I had an idea the other day looking at the bumpers and thought, he needs some dome hole plugs that would look like stock bumper bolts but don't weigh enough to make a difference. Something like these but might need a different size.  https://www.amazon.com/Mr-Gasket-5104-Chrome-Wheel/dp/B000BWE4CW/ref=sr_1_6?dchild=1&keywords=chrome+hole+plugs&qid=1626054839&sr=8-6
jh36
jh36 HalfDork
7/11/21 9:13 p.m.
In reply to NOT A TA :
There you go...that's what I'm talking about!  Thank you.
In the same vein, I need to drill a hole in the roof to gain access to the wedge adjuster...I will need a plug for that. I was thinking about a typical rubber floor pan drain plug unless someone has a slicker idea.
jh36
jh36 HalfDork
7/12/21 7:54 p.m.
Intel is in....1.5" on the rear and 1" on the front. It feels solid.
jh36
jh36 HalfDork
7/12/21 7:55 p.m.
7/13/21 8:37 a.m.
jh36 said:
Glad to see this.  Our mutal friend Judy has been talking up your car for a long time now.
AxeHealey
AxeHealey GRM+ Memberand Dork
7/13/21 8:59 a.m.
I love this car. Great progress!
jh36
jh36 HalfDork
7/13/21 11:07 a.m.
Thanks!  Yeah, Judy gave me her seal of approval when I swung it by here on the way to Summit Point.  And Paul insisted I fire it up so he could hear it...predictably, he is most interested in the sound of it!
jh36
jh36 HalfDork
7/13/21 7:44 p.m.
  • Ok, the hood supports are done and feel great, but adjustable if needed.
jh36
jh36 HalfDork
7/14/21 4:54 a.m.
I made a template for door jambs and cut the driver side.
0CGO83Y8QmxNcwVqRlAAH7XtT65qY2myNoVqBABUOMW83KTrWzOa5IsXLJsOv9kx
