Does this thread directly to the head? Can you get a dremel or something on it to cut the head off, slide the valve off the remainder of the bolt and then take it out with vice grips?
In reply to mazdeuce - Seth :
Me and Pete were messaging about this and I completely forgot about the fact that once the valve is removed more of the shaft will be exposed.
In reply to Daylan C :
Yea, I was mostly thinking how much it would suck to break it off flush with the head and how to not have that happen.
I was mostly suggesting he try to not cut the head off because from what he was describing as his access hole, I don't know of a way to get a headless bolt out flush with the head without pulling the engine.
That may well still be a problem, but I'm pretty sure that worst case scenario the head can come off and have the bolt hole cleaned up. Not a great solution considering what it takes to pull the head. It might actually be easier to drop/lift the entire motor.
This bolt does thread directly to the head. I am trying to not cut the head off because access to the bolt is not ideal.
Once the bolt head is cut off I would be able to slide the old valve body off. It's a possible option. Especially now that I have a new valve body with actuator and sender. But then I'm trying to get vise grips on it between the firewall and the motor.
I will attempt bolt removal tonight with the new irwin removal tools tonight and then evaluate what the nuclear options are if that fails.
Ummm.....
Easy button:
Pull the plastics off the cowl. Use harbor freight unibit to drill hole above offending bolt. Put six point socket, extension, and drive with impact through the hole.
Plug hole, reinstall plastics. Forget it ever happened.
Dusterbd13-michael said:Ummm.....
Easy button:
You've misunderstood what is happening.
All the cowl plastics and the metal access panel under them are removed. The offending bolt is pointed backwards into the firewall.. coming out of the head of the motor
Here's the FSM stuff for reference.
Take out the windshield, cut the cowl....
but seriously, what about pulling the front and rear mount bolts and rocking the engine forward? That was how you changed the rear plugs on GM transverse V6's.
bobzilla said:Take out the windshield, cut the cowl....
The nature of how the motor is bolted in. To get to that point. I'm pulling the motor. The 2 side mounts are fluid filled and not going to give well in that direction without a strap on something under major tension. I can pull the front lower mount and rear rear lower mounts to help with it, but it's still not going to rock well that way. This motor is fairly tall and that's where a lot of the trouble comes from. The very forward nature of the windshield is where i run into problems.
Alright.. The removal sockets arrived.
These are a far far superior design to the crap i got the other night at oreillys. These are also available at Lowes. I'll post a link to where I bought them on amazon later. The online reviews and reviews of 2 buddies put these as being the real deal.
VSA light went away immediately, used Torque app to reset the CEL.
Went out for a test drive. Let the car come up to temp.
Lights are all gone, and stayed gone. VTEC pulls hard to redline.
HAZMAT IS BACK!
And so i went to Popyeyes for a chicken sandwich.
Successful night all the way around!
Mazdaface and I will tackle the axle this weekend.
ScottyB said:w00t! nice work, rip all the VTEC's lil' HAZMAT!
ABSOLUTELY!
Also +1 for the use of Rick Flair!
WOOOOOOOO!!!!
Great fix.
Looking at that bolt, what brand sockets do you have? Might be time to invest in a good six point 10mm from a reputable brand.
I've never felt such a satisfying feeling like this to drive my own damn car to work.
Hazmat got up to temp and I closed my 25 minute drive to work with a full range rip through 2nd and 3rd. Damn that felt good.
