hotrodlarry
hotrodlarry Reader
7/18/11 8:31 a.m.
1997 Dodge Neon, automatic, SOHC
Replaced the coolant temp sensor the other day, started the car up afterwards and ran it for a few mins to check for leaks. I shut it off and came back a couple hours later and I had no power. No dome light, no lights on the dash,no click, no radio,nothin.Thinking I left the door not shut tight I had the battery tested and it needed to be replaced. Installed a new battery and same thing... no power, no lights, no sound, nothing.
Now I know I have a couple wires that are questionable (corrosion, missing insulation in some spots) but this is weird.it's like the battery is not even hooked up.I have had the car for almost 2 months and had no problems with it starting until now. Could the alternator have just quit all of a sudden?
EvanB
EvanB GRM+ Memberand SuperDork
7/18/11 8:35 a.m.
Could it be a main fuse or fusible link in the battery cable?
Duke SuperDork
7/18/11 8:55 a.m.
I hate to sound like Capt Obvious, but my Neons were always susceptible to bad contacts at the battery and it would come on quickly like that. Cleaned your terminals lately?
4cylndrfury
4cylndrfury SuperDork
7/18/11 8:55 a.m.
make sure theres nothing inline with that sensor that is awry. Couldve cracked the housing enough to have made contact somewhere and now like Evan said, you have blown a fuseable link or a relay is shot etc...
N Sperlo
N Sperlo HalfDork
7/18/11 9:06 a.m.
Check your ground. I've had bad grounds destroy lots of batteries.
hotrodlarry
hotrodlarry Reader
7/18/11 9:59 a.m.
New battery terminals...and they are super clean.
I triple checked to make sure the battery was installed correctly and it was.I installed it after a very busy, tiring day at work and even had a neighbor double check everything I looked at in case I missed something.The fuses looked good.I also checked the ground at the drivers side headlight which goes to the battery.That was cleaned and tightened down. I was told there's another ground that bolts to the bell housing. I am going to check that when it stops raining outside.
iceracer
iceracer SuperDork
7/18/11 10:00 a.m.
Besides the battery terminals check the main fuse or fusuble link as evanb said. CORROSION. there you go.
BoneYard_Racing
BoneYard_Racing Reader
7/18/11 11:02 a.m.
Could be a bad ASD relay the middle one right side of the PCD behind the battery. Its a standard 5 pole relay
njansenv
njansenv HalfDork
7/18/11 11:08 a.m.
try running a jumper cable from the ground on the battery to a clean spot on the shell of the car.
N Sperlo
N Sperlo HalfDork
7/18/11 11:18 a.m.
njansenv wrote: try running a jumper cable from the ground on the battery to a clean spot on the shell of the car.
+1
Could be a unidentifiable break.
Vigo
Vigo Dork
7/18/11 12:55 p.m.
I doubt it's a ground issue, personally. There are MANY MANY possible ground paths and the electrical system will use them until it literally burns them up. I think its on the positive side. You should basically have 2 or 3 wires on the positive terminal. 1 for the starter, 1 for the rest of the car, and possibly one from the alternator, although on a lot of cars that wire goes to the power distribution center (fuse/relay box). You almost certainly have an issue in the wire that doesnt go to the starter and doesnt go to the alternator.
njansenv
njansenv HalfDork
7/18/11 1:02 p.m.
Vigo wrote: I doubt it's a ground issue, personally. There are MANY MANY possible ground paths and the electrical system will use them until it literally burns them up. I think its on the positive side. You should basically have 2 or 3 wires on the positive terminal. 1 for the starter, 1 for the rest of the car, and possibly one from the alternator, although on a lot of cars that wire goes to the power distribution center (fuse/relay box). You almost certainly have an issue in the wire that doesnt go to the starter and doesnt go to the alternator.
While you certainly might be right, I've had this problem on multiple neons. I had one that for two weeks had a booster cable under the hood running from the bat neg to the chassis until I could find time to run a new ground. Both times, the chassis ground (pass fender) was bad.
hotrodlarry
hotrodlarry Reader
7/18/11 9:02 p.m.
There's 4 cables coming off the battery. On the pos (+) it's one to the PDC and one to the starter. One the neg (-) it's one to the radiator support and I think the other to the bell housing.
I know current will follow the easiest path it can, which should mean anything near the battery/PDC is where the issue lies. I could be wrong though.
Vigo
Vigo Dork
7/18/11 10:22 p.m.
Hooking jumper cables from the engine to the battery negative will confirm or rule out a bad ground connection between those two points. I would do that just because it is a quick yes or no. But after that i'd be looking at the one going to the PDC.
hotrodlarry
hotrodlarry Reader
7/24/11 5:26 p.m.
think i found the problem.
this is where the positive cable goes into the underhood power distribution center. looks like somehow it corroded enough to separate that piece where the two studs are.
anyone know how i can fix it?
triumph5
triumph5 SuperDork
7/24/11 6:37 p.m.
You might want to give the good folks at Rhode Island Wiring (not the exact, correct name, but, googleing will get you the correct name and URL.). Painless Wiring, too.
.Two wires bolt to the posts, which then distribute the power through the distribution block? If so, sounds like the easiest would be to go to the dealer, after trying a junk yard. It's such a specialized part.
hotrodlarry
hotrodlarry Reader
7/24/11 8:15 p.m.
Actually, one cable bolts up to both bolts. It sucks cuz I had checked the cable the other day, but didn't take everything apart until tonite.I didn't venture too far into tearing the power distribution block apart but maybe I can get just that piece. I'd hate to try to switch that block out with a different one.
Hmmm.. now that I think of it, the guys from Shelby East are just across town from me. Maybe I can ask them.
fasted58
fasted58 Dork
7/24/11 10:11 p.m.
The Druids would light new fires and paddle a canoe
Streetwiseguy Dork
7/24/11 10:55 p.m.
Ignoring the obvious canoe, I'd head for the pic'n'pull for a new to you box, then dig around in it till you figure out how it comes apart. You can probably swap the lug into your box.
Hint: take a few photos of where all the relays and fuses are before you pop them all out.
Vigo
Vigo Dork
7/25/11 12:25 a.m.
Apparently i win again.
hotrodlarry
hotrodlarry Reader
7/27/11 4:40 p.m.
Streetwiseguy wrote: Ignoring the obvious canoe, I'd head for the pic'n'pull for a new to you box, then dig around in it till you figure out how it comes apart. You can probably swap the lug into your box. Hint: take a few photos of where all the relays and fuses are before you pop them all out.
That's just what I did today.... minus taking pictures.The local yard hit me up for $15 plus I got to keep all the fuses in the box ( which were still good, bonus!)
At more than one point I thought I was in over my head, but after a couple hours, the car started... then wouldn't shut off. I had two wires crossed up and I knew those were the only two I had unclipped. I switched the wires back, and the car started again and shut off when I turned the key.
Here's what that little piece looks like.
I definitely do not want to change one of those out again.if I do, it will be for someone else and I'm gonna charge an hourly rate, lol.
Now off to figure out why my radiator fans still don't work.
5EI9UOaS5ba8KRPMmJesEktl9Qucq2yFOcLc8QpZ8EU2yeanJzVRfmrNEK1q6IBI
