ChrisTropea
ChrisTropea GRM+ Memberand Associate Editor
8/1/23 8:54 a.m.
https://www.youtube.com/embed/1umWh4wmr-g
Can you turn an old cop car into a canyon-carving sports sedan?
Jim Leonard, the owner of this 2008 Ford Crown Victoria P71, explains how he did just that.
Watch more videos
Scotty Con Queso
Scotty Con Queso UltraDork
8/1/23 11:16 a.m.
Awesome stuff.  Jim is a great dude!
J.A. Ackley
J.A. Ackley Senior Editor
8/2/23 9:48 a.m.
The Crown Vics are certainly a growing class in the oval-track world. It's no wonder why.
AnthonyGS (Forum Supporter)
AnthonyGS (Forum Supporter) PowerDork
8/2/23 10:11 a.m.
Now I'm looking at LS powered Caprice police cars again.
edizzle89
edizzle89 SuperDork
8/2/23 1:13 p.m.
I found removing 1100+ lbs helps quite a bit too
HalfAssedStillFast
HalfAssedStillFast New Reader
10/13/23 11:56 a.m.
Do you have a write up on Vickolas somewhere?
10/13/23 7:34 p.m.
I am not going to say that I have slid a PD's P71 around while taking an offramp too fast, but the suspension on those worked well with the police spec tires and vice versa.
The tires were like $200 each in 1998 dollars.  That was about as expensive as tires got.  Even Gatorbacks, known for being silly expensive, were about $200-250 each.
Javelin
Javelin MegaDork
10/14/23 3:33 a.m.
Yes.
tester (Forum Supporter)
tester (Forum Supporter) HalfDork
3/25/24 11:37 a.m.
In reply to Pete. (l33t FS) :
The chassis, suspension, and steering were updated in 2003.  The later cars have rack and pinion steering and other improvements.
3/25/24 7:55 p.m.
In reply to tester (Forum Supporter) :
They look a lot like Volvo was told to go to town on it.  At least, the construction methods between its front end and a P2 chassis Volvo are very similar.
And curse those damned obtuse-cone ball joint and tie rod tapers.  GM didn't see a need to do that.
jkstill
jkstill New Reader
6/16/24 2:21 p.m.
In reply to Javelin :
looks like you have a ticket under the wiper there.
DasAuto
DasAuto MegaDork
6/16/24 4:12 p.m.
Run card. SCCA ProSolo in Packwood in 2008. I was way ahead of the curve on Crown Vics.
Hooligan61
Hooligan61 New Reader
12/26/24 6:08 p.m.
I autox'd a 93 P71 back in '02 and '03 and won the F-Stock title both years with our tristate club. People would complain how tight our gates were, and the organizers would say hold on, then I'd run through and not cone. It was a hoot to drive. One set of pics at an event in NJ showed so much weight transfer in the slalom, that the inside front wheel was off the ground except for the inner most tread block. It was the biggest momentum car I've ever driven, if you touched the brakes you lost decades...Now there's so much more involvement and improvement, I'd love to do it again.  😂
ShawnG
ShawnG MegaDork
12/26/24 6:50 p.m.
GM made the police Tahoe handle as well as the Caprice so, why not?
X5MijVbdbu1cM7TMUQQ1quJIFRA3JlrUhsTdrGS5XznfKVx8XEyERNlj4JI5BeUN
