Apexcarver
Apexcarver SuperDork
10/30/09 5:14 p.m.
I have a 1986 325e and there is a guy locally who rearranged the font end of his 325i at a drift event.
mine is an auto and his is a manual
mine is 4door his is 2
Can I use his transmission to swap mine to a manual( i trans into an e)?
what is the total parts list I should want off of his car?
the list that comes off the top of my head is
trans
shifter
driveshaft
clutch/flywheel (resurface flywheel and maybe new clutch)
master/slave cylinder?
computer?
again, please if you know the total parts list, let me know!
If anyone knows where there is a good writeup for this swap please let me know! (been looking for about an hour)
ddavidv
ddavidv SuperDork
10/30/09 5:23 p.m.
Bimmerforums E30 The answer is there somewhere. I don't have time to do the searching for you, but I've seen the auto to manual topic there dozens of times.
Sonic
Sonic Dork
10/30/09 6:12 p.m.
Why not just get the whole thing and do a complete driveline swap to get the more powerful motor along with the package
Apexcarver
10/30/09 7:09 p.m.
Sonic wrote: Why not just get the whole thing and do a complete driveline swap to get the more powerful motor along with the package
because the neon green painted valve cover and purple intake manifold tell me that I would rather stick with the motor that I have...
I am thinking about getting the whole car and parting it myself, but my landlord (mom) might murder me.
stuart in mn
stuart in mn SuperDork
10/30/09 7:14 p.m.
I don't think you need the computer, and the driveshaft may be different but I don't know about that. What you could do is go to www.realoem.com and search the part catalog - you can either call up the part numbers for each car and see if they match, or you can find a part number and then check to see what all cars that particular part fits.
ddavidv
ddavidv SuperDork
10/30/09 7:18 p.m.
Strange how things just appear before me without looking: Auto to stick how-to
Apexcarver
10/30/09 7:37 p.m.
ddavidv wrote: Bimmerforums E30 The answer is there somewhere. I don't have time to do the searching for you, but I've seen the auto to manual topic there dozens of times.
Cant find a specific thread, but from one I found it seems an I trans wont work in my E.. shucks...
still.. need to gather a parts list.
2002maniac
2002maniac Reader
10/30/09 9:08 p.m.
The trans would work, but it doesnt have the mounting hole in the bellhousing for the reference sensor.
Sorry to be the bearer of bad news.
I suggest you swap the whole drivetrain regardless of the color of the intake/valve cover. Does it run right now? Warm it up and do a compression test. If the numbers are decent, go for it!
2002maniac
2002maniac Reader
10/30/09 9:15 p.m.
When you do find an e car with a 5-speed, you need about everything.
from front to back;
pilot bearing flywheel clutch TOB clutch slave clutch pedal clutch master trans shift linkage guibo driveshaft
All this can come from the same donor car, 2-door/4-door makes no difference
edit** what the berkely! I worked so hard to do an html list and it didn't work! What did I do wrong?
I put this around each list item; < li >< / li >
curtis73
curtis73 GRM+ Memberand HalfDork
10/30/09 11:50 p.m.
Most i cars had the Getrag 260 while most e cars had the 240. The 260 is a bit stouter, so your swap should be fine. Do a new input shaft bearing while its out. They're an annoying failure point.
Take the whole drivetrain and put his i head on your e block. Then you basically get a higher compression i with 2.7L.
Apexcarver
10/31/09 12:00 a.m.
I think your wrong there curtis..
if you put the I head on the E it drops the compression absurdly low according to almost every source i have seen
(talking NON-super eta)
2002maniac
2002maniac Reader
10/31/09 10:37 a.m.
curtis73 wrote: Most i cars had the Getrag 260 while most e cars had the 240. The 260 is a bit stouter, so your swap should be fine. Do a new input shaft bearing while its out. They're an annoying failure point. Take the whole drivetrain and put his i head on your e block. Then you basically get a higher compression i with 2.7L.
wrong and wrong
e cars and i cars got similar G260 transmissions
i head on the e block yields rediculously LOW compression.
x4EdMLSC1QAC4uVLmHxVF0EEfyB17rI2QlD64Spskcv8KCq4jooTlWVzz57tOCn3
