poopshovel
poopshovel Dork
11/21/08 12:46 p.m.
Since it's gotten freezin' ass cold here in Joe-Juh, I've had some trouble getting the Integra to start in the mornings, and in the afternoon when the car's been sitting all day.
Ignition switch is less than a year old (and I removed my 5 pound wad of keys at the same time,) battery is less than 2 years old, and alternator is less than 6 mos. old. Had the starter checked while diagnosing the ignition switch (around a year ago?) and it was fine.
I've been bump-starting it in the driveway, and on the street to get to and from work, and occasionally the car will crank after 2 or 3 tries. Otherwise, there's just a "click." Whacking the starter doesn't seem to do any good. Car will crank with no problems when warm.
Any thoughts? Main Relay? Starter on its way out?
sachilles
sachilles Reader
11/21/08 1:31 p.m.
what is the battery voltage, before you get the "click"?
My guess is a bad starter or starter solenoid.
Sonic
Sonic New Reader
11/21/08 5:21 p.m.
Try cleaning off all the grounds and making sure the connections at the starter are clean and tight. Try the battery terminals too, I had an intermittent no start on a Civic from having a not obviously loose battery terminal, it wouldn't let the car pull the amperage that the starter was looking for.
If that doesn't solve it, yea, starter.
2lgUBwJD9nwZk6MGgDTrj0STKu86q7wZwg7XGFzcF2TrZLauiUlZZfYzmhLqN6Fl
