In reply to frenchyd :
I will use an example to demonstrate what I'm talking about. Pictured below is what remains of the left side rear wheel snubber. It's a rubber piece (the rubber bit has broken off on this one, so I replaced it last night) that rides between the tire and the inner fender well, likely to prevent the tire from rubbing on the inner fender in the event of a severe suspension compression.
See those two nuts on the top? They're both fine pitch, elastic stop nuts ("Nylocks" as we refer to them at work). Due to their proximity to the inner fender liner behind them, they are impossible to remove with a socket of any sort. So, an open ended wrench must be used. However, due to their proximity to the metal gussets on either side of them, it's impossible to turn them more than one flat at a time. And, there's not enough room for the nuts to be removed until they are both unthreaded completely, so they must each be loosened about 10 flats at a time, until they can both be removed, along with what remains of the snubber bracket. Due to the built-up crud on the threads, I was able to unscrew them just enough to provide room to get a small cut off tool in there and hack off the rest of it.
Of course, installing the new snubber was the reverse of removal- which is to say, a slow, arduous process of threading them in one flat as a time, 10 flats per side, alternating back and forth, until the whole thing is tight.
If this were designed properly, (this is coming from someone who is a mechanical engineer, and does stuff like this for a living), the nuts would have been accessible with a socket, and the replacement would have taken roughly 2 minutes with a hand ratchet. Instead, the replacement took 15 minutes. That's an extra 26 minutes per car, for both sides. Even if we just look at the assembly process, for when the car was built new, it likely added 10 minutes or so to the time for each car. Times 25,000 cars built, that's an extra 4,166 hours of assembly time. All for poor design of this one part, that would have cost nothing more to design better.
Now imagine the entire car is FULL of examples just like this. End result: bloated assembly times, unhappy workers who have to assemble stupid, poorly-designed E36 M3 with an open-ended spanner, poor quality (how many of these rolled off the lines with those nuts loose...or one missing?) and terrible serviceability.
Yes, these are great cars, wonderful to drive, and learning to work on them is a challenge that I accept and do enjoy. As an engineer, I also enjoy looking for lessons learned and questioning why things were done the way that they were.
