hotchocolate
hotchocolate
9/13/10 8:10 p.m.
Hello guys, If there is any group in the world that can help me with this it is you. Anyway, my sister-in-law had a baby so i decided to go visit her. About 15 miles outside of Janeseville, WI i hear this loud noise. Thinking i have a flat i stopped to check. NO flat, but there is a loud rubbing noise. I looked underneath the car and saw nothing missing. I limped the car to my destination only to find out that i just lost a rear shock mounting bolt and have a flat (from driving on the shoulder of I-90).
The baby is beautiful--less than 24 hours old and the smallest human I have ever held:)
All this to to ask: Where can i find a replacement bolt ASAP? is there a non BMW replacement i can use to get me back home? I will be trying the junk yards tomorrow. Fortunately my wife is here and i can use her car.
Any input will be greatly appreciated. Thanks in advance.
Junkyard_Dog
Junkyard_Dog Dork
9/13/10 8:14 p.m.
If the same bolt on the other side is still there just remove it and match it at a GOOD hardware store is all I can think of.
Edit: what chassis number? How about RealOEM.com ? When you finally get to the photos there is a callout for length and thread size on the bolts and hardware.
hotchocolate
hotchocolate New Reader
9/13/10 8:25 p.m.
E36. I thought about removing the other one, but i figured i will ask first. No tools so i want to find the easiest way to do it. i will check the real OEM site. Thanks for the input.
Junkyard_Dog
Junkyard_Dog Dork
9/13/10 8:41 p.m.
hotchocolate wrote: E36. I thought about removing the other one, but i figured i will ask first. No tools so i want to find the easiest way to do it. i will check the real OEM site. Thanks for the input.
If you click on my link it should bring you right to the rear shock picture for your car
hotchocolate
9/13/10 9:14 p.m.
Thanks for the link. It was very helpful. I will check the hardware stores tomorrow. I found an M12x1.5x50 at oreilly's. hopefully 60 is not too hard to find.
WilberM3
WilberM3 Reader
9/13/10 9:41 p.m.
its probably a hardened bolt of either 9.8 or 10.9, if not 12.9. if you can read any ratings on the non-broken bolt head try to match that up.
93gsxturbo
93gsxturbo Reader
9/13/10 10:06 p.m.
Would a 50 work in a pinch? Otherwise Fastenal can overnight it if they dont have it in stock, and there is a good chance there is a Fastenal near you.
9/13/10 10:50 p.m.
in a pinch.. you could just remove the rear shock completely.. it will be an odd ride, but it will get you home..
hotchocolate
9/13/10 10:54 p.m.
Thanks, i will check fastenal. If they dont have it i will try to use the 50 to get me home. i will keep y'all up dated
irish44j
irish44j HalfDork
9/13/10 11:03 p.m.
McMaster-Carr is another option if fastenal doesn't have one in stock...
unevolved
unevolved HalfDork
9/13/10 11:57 p.m.
Check Ace Hardware. I've been impressed with their hardware selection in the past.
ansonivan
ansonivan HalfDork
9/14/10 6:40 a.m.
Have you checked the condition of the threaded hole in the rear trailing arm? I've seen people loose those bolts on a few occasions and the trailing arm has been damaged about half the time.
Also, don't try forcing the incorrect bolt into place or using a shorter one, replacing the trailing arm is no fun.
If it happens to be the passenger side trailing arm I do have a spare M3 arm I can ship you for a bargain basement price.
9/14/10 8:40 a.m.
what model of BMW is this anyway? If it is e30 shaped, you CAN run without the rear shock. I did it in my Ti when the bilstiens worked their way loose OVER the stock mounting bolt. I was on the PA turnpike when the car started behaving oddly, a look under the car showed the shock just hanging there.
A trip to the nearest Lowes netted me the washers I needed to put that problem to rights.. but it was a 30 mile trip at highway speeds..
hotchocolate
9/14/10 11:06 p.m.
Thanks guys. I knew i could count on you. The realoem website was/is very helpful. I found a temporary fix (8.8 m12x1.5x60) at ACE hardware. I made it home safely. I will order the proper part and make it a permanent fix.
XLMeysVXW2wVfDnYpvwtlX3ccEoXgdITJrR9tdU5xj2SBU3GO1pFrVi91SQsz86f
