From the early turbocoupes (85-86) using the Garrett T03 turbo, where might I find the oil restrictor? Is it the 90* fitting at the top of the cartridge (the porting looks a bit large, IMO) or is it located elsewhere in-line witht he oil feed?
I don't believe there is a separate part that can be called a restrictor. Stock parts are adequate. Are you getting smoke or oil in the intake? Some folks at turboford have done some work with restrictors for different bearings or other considerations.
http://www.turboford.net/ubb/ultimatebb.php
Bruce
Thanks Bruce. The turbo is going on the Challenger, so no smoke....yet. The piping size that I have is small diameter-wise, but from various turbocharger installations I've come across, it seems there was something else to limit oil pressure to the turbo. I'd like to avoid popping a turbo the day before the event :).
