mj_wils1970
mj_wils1970 New Reader
2/29/16 10:33 a.m.
I was changing my timing belt for the first time and when I removed the crank pulley I got a good look at how much rust was on there. So naturally I started to clean it off. I was planning on painting it when I started wondering if I'd throw the balance off and destroy the crank.
Would removing the rust and painting kill my crank balance?
2/29/16 10:54 a.m.
Not unless we're talking about spectacular amounts of either.
mj_wils1970
2/29/16 10:56 a.m.
Thanks, although if the engine did go on me it would be a reason to put a 1.8 in it
mj_wils1970
3/9/16 9:01 p.m.
Just to add another question to this topic, I heard that the bolt holding the timing gear on is a single use item. I've already got the woodruff key and was planning on reusing the bolt with blue loctite. Would that be ok or should I replace the bolt? My car is a 90 SNC FWIW.
3/9/16 10:29 p.m.
I don't think it's single use, but it's cheap so a lot of people replace it as a matter of course. The Loctite and the correct torque are the important things.
auwIB3ulqSHFDniO1IfOIZZBb8AffLQNtQYePhaDyLTn2Hoe6MieXHf7a3T7pVrG
