Spoke at length with SPI tech. Berry is awesome, again.
He looked at the pictures, its hard to diagnose over pictures and the phone, but here is his best ideas. First, likely contamination. I wiped the roof, the contaminants were wicked up into the solution, which ran down the sides and dried there before I could wipe it back off. I did wipe the sides down too, but possibly big deposits in those areas were hard to re-lift after it dried.
Laquer thinner, it was months ago, but similar idea, he said since it flashes even faster than wax a grease it deposits contaminants even more in a similar manner. But it should be well flashed off and the not the root issue.
We talked air lines and filters, I did not drain my tank (petcock i think is stuck, and VERY hard to access. I do have a water trap (T with 6" pipe and ball vlave) just after the flex coming out of the compressor. I did open that, not real water. Then it goes thru my "cooler"
(big coller coil thing) and into another water trap. Then rises ~4' into a typical water oil separator/regulator (admiditally a cheap one). Then my 1/2" hose to the gun. I did try adding my dessicant filter right at the gun after the first issues showed up. No change. Tried a different gun, no change.
So the reg/filter may not catch tiny particles. I did not use a little round filter at the gun, but Berry said they are pretty useless anyway. Perhaps part of the issue. I will try to drain the tank.
I wiped with lots of wax and grease ~1-1.5 hours before spray, heat was on at 75+ in the garage, I would think it would have flashed, but maybe not completely. I did tack rag right before spraying, perhaps that dropped something?
In reply to NOHOME :
See above on the laquer, not useing for panel wipe. I will need to be more careful on my wax and grease remover application.... I did more scrubby scrubby. But multiple times!!
Nope screen was removed from the cup. SPI clearly has that in their instructions :)
I was spraying on cardboard.... I think my finger was hitting the air adjuster on the base of the gun and I kept trying to compnesate. I was good and frustrated at that point....
Yes I need to get reg on gun, I did try my clear gun that has reg on gun, same issues. And I think I broke the reg. See frustration above....
I have a 1/2" hose, set pressue to ~30 at the wall with trigger pulled.
Berry wiht SPI suggests wet sanding wiht 800 or 600 at most to knock it all back to smooth. Then shooting another coat over it. I also would not have had nearly enough paint to do two coats. I used 1.5 qts sprayable, and did not even have enough to do the windshiled frame around the bottom. I also think I was putting it on too thin.... The one good spot is on the back window frame, where its tight to the garage door, I think I was much closer to the panel and put a lot more on. That 3"x18" strip is glossy and smooth!
I need to get this thing done. I was on a roll, feeling excited. Last night sucked. A lot. I scheduled today off to shoot clear and do the lace :( I still feel a bit crappy. But that wont help anything. My wife comes home (part of why I could get things done is no one complains about long hours in the garage) tomrrow.... I will try to keep making progress. I ordered 2 more quarts of white, one more grey just in case. and SPI's wax and grease remover. Just in case again. More $$, and now go wet sand for berkeleying hours. Of course the door frames are all rounded and curvey.
Need to stop and buy paper on the way home. And a new DA.....
