1 ... 115 116 117 118 119 ... 159
tuna55
tuna55 MegaDork
11/21/20 6:11 p.m.
So the gaskets are all present. The rear seal isn't leaking. The speedo connection is lot leaking. It seems that the reverse shifter arm is leaking. I didn't know that was a thing. It does penetrate the case, so I guess there's an o ring there. Time to check that out.
In others news the wiring is a mess.
tuna55
tuna55 MegaDork
11/21/20 6:18 p.m.
It's called a shift shaft seal. Time to buy some
11/21/20 6:37 p.m.
Wiring?
If you need me, let me know! Cant be too bad....
tuna55
tuna55 MegaDork
11/21/20 6:39 p.m.
tuna55
tuna55 MegaDork
11/21/20 6:53 p.m.
Dusterbd13-michael (Forum Supporter) said:
Wiring?
I'm trying to decide what to do in the engine compartment. I'm strongly considering buy once cry once and buying from the guys you mentioned. It's all there but it's ugly and miserable.
11/21/20 7:15 p.m.
Offer stands.  All you need to do is let me know!
tuna55
tuna55 MegaDork
11/21/20 7:27 p.m.
Tell me where these go
tuna55
tuna55 MegaDork
11/21/20 7:31 p.m.
Replacement o ring ordered. It's an or114
tuna55
tuna55 MegaDork
11/21/20 7:32 p.m.
Do you have any good color wiring diagram? I'm a bit stuck mostly on where this all goes again.
tuna55
tuna55 MegaDork
11/21/20 7:35 p.m.
Like this
https://67-72chevytrucks.com/vboard/showthread.php?t=185856
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) UberDork
11/21/20 9:14 p.m.
Heater motor and blower resistor, perhaps?
tuna55
tuna55 MegaDork
11/23/20 7:13 a.m.
Maybe.
I will go back out there in a few nights, hopefully with Tunakid #2 again, he enjoyed the time we had out there.
I spent way too much money buying things. Stay tuned.
tuna55
tuna55 MegaDork
11/30/20 7:21 a.m.
Time is tighter than ever, money is pretty difficult as well. I got some time out there with Tunakids #2 and #4 though. Happily, we got the exhaust manifolds off and treated. We removed the old water pump and broken shroud. Unhappily the new water pump broke when I put in the hose nipple, and also unhappily I don't have enough bolts to actually put the manifolds back.
Also no pictures. I am not good at being my own photographer.
11/30/20 7:58 a.m.
Im just happy to read about progress!
tuna55
tuna55 MegaDork
12/2/20 8:05 a.m.
I hope people are still reading.
Long ago we had a discussion about replacing bolts, and I have long since replaced them. Back then I had three or four guys offering to have me send the bolts and they would clean them with some special sauce and vibratory magic. At that time I really didn't have the bolts and it was not useful.
Now I am going to reassemble things and I have a pile of rusty nasty bolts, and would like that same service if it is still offered. Let me know if anyone is still willing, and what the terms might be.
Thanks!
tuna55
tuna55 MegaDork
12/5/20 6:40 a.m.
I'm perfecting my shift shaft seal pushing tool
Anyone still reading and want to help with vibratory cleaning on my pile of bolts?
12/5/20 10:15 a.m.
If you can't find a vibratory cleaner, I've spent significant time wire-wheeling ALL the cab/body bolts on my '61.  They are clean enough now.
12/5/20 10:16 a.m.
Nice lathe.
tuna55
tuna55 MegaDork
12/5/20 10:53 a.m.
SkinnyG (Forum Supporter) said:
Nice lathe.
It's at work but it's free for me to use. Nice perk, eh?
NOHOME
NOHOME MegaDork
12/5/20 11:13 a.m.
Not only following but rooting for each update.
  Myself, I am still at the wire wheel stage of hardware cleaning. Evaporust does a great job if you are just dealing with surface rust after a previous clean.
Pete
I'm following.Despite being non-vibratory, for those nuts and bolts, I recommend a jug of evap-o-rust. Environmentally friendly, effective, ok to get on your hootus.
NOHOME
NOHOME MegaDork
12/5/20 11:49 a.m.
In reply to wheelsmithy (Joe-with-an-L) (Forum Supporter) :
I shall not ask the obvious.
12/5/20 1:04 p.m.
I bought a Harbor Freight vibratory tumbler. It caught fire on the third batch of Bolt. Would not recommend.
tuna55
tuna55 MegaDork
12/7/20 4:53 p.m.
tuna55
tuna55 MegaDork
12/7/20 8:24 p.m.
The hootus looks better than ever!
dpKIYdhpY7NpDuFSrv0kw4Ac7lWYU88duzhxTj2EgyG9inK8QPCnb7YQLUa4VCpL
